Vray 7 Hotfix 3 Crashes Sketchup 2025 when I try to change the render output settings.
Hello nihar_sail,
Could you please confirm if this topic is related to the ticket number 364748 that you have opened to our support?
In the video you have sent the crash is GPU-related and the V-Ray version that you are using is V-Ray 6.
I will also contact you in a ticket to continue our investigation.
I would like to share an update on this case. Thanks to Nihar's cooperation we were able to identify the issue, caused by following combination:- Enscape Extension versions 4.5.0.485 or 4.5.0.490 installed;
- Camera is set to Two-Point Perspective in SketchUp;
- Changing V-Ray Render Output settings leads to a crash.
