Load Error
  • Load Error
    Vray beta seems to install fine (also run a repair), but when I run SU I get a warning dialogue:
    'Activation Manager Init failed(126) - The specified module could not be found.'
    I then get the following load error:
    'Error loading File VrayFOrSketchup.rb
    1114:A dynamic link library(DLL) inialization routine failed.
    C:\Program file\@Last Software\SketchUp5\Plugins/VrayForSketchUp.so'
    I'm running a PC dual core Intel Xeon 3.2GHz 3.19Ghz with 2GB of RAM and a network version of SketchUp 5.
    Thanks for your help...looking forward to seeing what it can do.
    Cheers
    Paulus[/img]
    Load Error
    Paulus-
    Typically this is the error you get if you do not have admin rights to install software. The VfSU installer needs admin rights to install. If you have admin rights please let us know. Otherwise try installing with admin rights and lets see what happens.
    Corey
    Corey Rubadue
    Director
    Chaos Group
      Load Error
      thanks for your help, I had logged on as an adminstrator to install, but did not realize that you need to be logged on as an administrator to run the program also.
      Thanks
      Paul
        Load Error
        paulus,
        I am curious if you got VfSU to run, did you?
        Corey
        Corey Rubadue
        Director
        Chaos Group
          Re: Load Error
          same problem again
          i'm already log on as administrator, but still having the problem..... pleaseeeee help.
