ok guys, a new problem (?) for you:
i'm tryng to render a net, so i've made a painted surface in SU and created my linked material. Then i try to give transparency & bump to this surface, but:
- i must give transparency after each render (yes, i click on "apply" before launch the render)
- i use the same texture for the both effect (a b/w jpeg) but i see in the material preview just tue bump effect: no transparency!
- last but not least: i don't see any effect (bump & transp) in the final render!
what did i wrong?
here is a screenshot with the bump & transp values (you can see the material preview)
what did i wrong?
