batch render , linked material
  • batch render , linked material
    Hello agvis people.
    1.Today i tried "batch render utility": rendering animation with 1 frame per second+ transition
    1 sec. between scenes- it works good. But, it does't render last scene (maybe you should add a "loop" option).
    The workaround is to duplicate the last scene (if you want it to be rendered).
    The issues begin when I change sun parameters (lokations,daytime.. etc.)- the render quality is becoming pretty cr@ppy.
    2.Linked materials:
    When I make linked material, then right click
    on this new one-> import material->getting preset mat (let's say frosty glass), it works good with existent geometry with assigned material,
    but vray doesn't implement this link to new shapes with the same SU mat. Bug?
    Re: batch render , linked material
    hmm - I need to verify that I am parsing the pages properly I suppose. And what do you mean by "the render quality is becoming pretty crappy"? Does that mean that each frame of the animation is getting worse and worse?
    2.Linked materials:
    Interesting - I've never tried importing into a linked material, so that probably is a bug.
    Joe Bacigalupa
    Developer
    Chaos Group
