Resolution Problems
  • Resolution Problems
    I am trying to render images at a high resolution, but the highest Vray is letting me render images at is 1600x1199, which is the viewport size. I am checking the overide button and putting in a higher resolution but it will only render at the viewport size. Is there another setting I should change??
    Dave...................
    Re: Resolution Problems
    The educational version of VfSU has a resolution limit of 1600x1200, so thats what seams to be going on.
      Is there any way to change this or to upgrade????????????
        Email support@asgvis.com and explain your situation. Make sure to include your serial number as well. They should be able to help you find a solution.
          Ok thanks.............................
