Render trouble
  • Render trouble
    I've never posted an image.. here it goes.
    Re: Render trouble
    Now here is the sketchup pic.
    For some reason, that's what came out. Another thing is that i rendered another image and i couldn't get the sunlight to go through the window. Suggestions? I used the "architectural glass" and followed the tutorials, and no luck. Im gonna post it as well.
      Re: Render trouble
        Re: Render trouble
        The glass looks all messed up because its a single plane as opposed to a solid(closed box). In order to calculate materials with refractions correctly v-ray needs an entrance surface and an exit surface that can only be achieved through solids or you'll get artifacts like these. If it has a refractive material then its pretty much got to be modeled as a solid.
          Re: Render trouble
          Good point there, it makes so much sense. Thanks a lot.
