Some problems with rendering
  • Some problems with rendering
    When i try to render with gi_irmap_medium.visopt(for example any options with ir.map), i can see only last-linked material(with objects),.. all white(blank, all objects with mats) in Vfb.
    I try to render with "default" settings - all are normally displayed in Vfb.
    Can somebody helps me? :'(
    Re: Some problems with rendering
    Could you send me the scene and some instructions on how to reproduce this behavior? I'm not sure I totally understand what is happening.
    Joe Bacigalupa
    Developer
    Chaos Group
      Joe thanks!
      I remove this scene.
      I solved such: re-install vray4skp and re-work model(export to dwg-format...).
      I don't know why it(vray) linked to one material(with objects) and render it only with gi_irmap_medium.visopt...other objects(mats) wera blank-white.
      P.S. check - vray4cinema4d will come 17th September/
      do you work at revit-bridge?
        We are not actively developing the Revit tool at this time. We do have a working code-base for the Revit to V-Ray exporter, but it is on the sidelines at the moment.
        Joe Bacigalupa
        Developer
        Chaos Group
