After I installed SR1 the ability to copy multiple items with the use of the 'move' command did not work. For instance when you copy an item using the move command, if you type a number and 'x' immediately afterwards, it will do a multiple of the item at the same distance.
I uninstalled V-Ray and it was working again. I then reinstalled V-Ray SR1 and it was disabled so it is definitely due to the new release.
Anyone else having the same issue?
