Vray SR1 crash when apply the material on non-flat surface
  • Vray SR1 crash when apply the material on non-flat surface
    Guys please help me. Since i install SR1 version. everytime i apply the material onto any non flat surface. the SU crash. i try to unintall Vray SR1. Then Su back to normal. so i pretty sure is SR1 problem. Even i try to import CAD model into SU. once i apply material on any face of the model. It crash.
    Urgent to get help. need to finish 3 job in 2 weeks.
    Re: Vray SR1 crash when apply the material on non-flat surface
    When you apply a Vray material to a high poly object, such as curved surfaces you have to be very patient.
    It needs a lot of calculation time.
    If you have the layer toolbar open (with that yellow box), you will see it starts flickering when you apply a vraymtl to such an object. Don't move your mouse until the flickering stops. Sometimes it means even waiting for half an hour....
    And sometimes the polycount is just too high and it crashes anyway.
    It's just the way Sketchup is programmed (very badly if you ask me) and not really Vrays fault.
    However, from a coders point of view it IS possible to avoid it (note : I am not a coder).
    The Skindigo plugin seems to overcome this issue. It is written very clever to handle these things.
    I invite Asgvis team to download it and examin how things are done. Indigo is not a competition to Vray as it is an unbiased engine, but the render plugin is written very 'KISS' (Keep.It.Simple.Stupid)....
      Hi Biebel,
      Thanks for your suggestion. the problem i have is not like that easy. I try to unintall Vray SR1. Then i do the same action to apply the material. it's was fine. Sadly once i reintall Vray SR1 into SU. Problem come out. I can't aplly any material on any flat surface even the surface on angel. Once i apply the material. Programe closed then Bug splash diagrame comes out.
      By the way i am intalling VRAY SR1 academic version. Is there anyone have the same problems. Or vray helper can look at that serious issue?
        I had reported a similar problem, where the crash happened when I tried to applied a texture directly in sketchup. I was advised that the workaround is:-
        first add the textured material to the model (right click the material and choose add to model), you should be able to use the paintbucket tool to apply that material while selecting it from the "In Model" section.
        David
        Sketchup 2015
        Vray version 2.00
        www.davidcauldwell.co.uk
          hi dcauldwell, you are right. I need to create the material in Vray then apply to the object first in the first time. after that then i can use the paint on to any other face.
          that's meant the bug is between the link of vray material and su material. I am supprise not many user find out this simply tast problem...it just a su normal way to apply the material. ??????????
          I hope Vray guys can look up this serious problem.
          i knew you guys working hard on that but the vray for 3ds max is quite developed. if this is the only little bug and make it the right version coming as quick as you guy can. a lot of customer will jump back to using vray for 3ds max or something else. the su users is dramatically increase in % very high from other 3d software. hope you guys won't diappoint to them.
          good luck
          Thanks to dcauldwell again
          cheers
            Hey guys, we just fixed the bug that dcauldwell mentioned, yesterday. A new version was posted on our site today. We apologize for the inconvenience.
            Devin Kendig
            Developer
            Chaos Group
              Asgvis is doing good !!!
              Those quicker updates are good service.
                well done. guys.
                I like your passion of the improvement for the software. But remember ..keep working hard
                Thank you very much to taking that problem seriously.
                Cheers.
                Well done
                  I see the uploaded data had changed, but it still says 1.00.70.
                    And while the File Date also claims 06 Jun 2008, I do actually get 1.00.71. Might be worth updating the download page info.
                    Also, is there an updated manual somewhere?
                      Thanks for the heads up, I'll see if I can get someone to update that info for you guys. The manual has been revamped as of SR1 official release. There should not be any updates to the manual until the next big release of our product. We don't plan on adding any features or changing the workflow of anything until then. We are still trying to fix a couple bugs that popped up after the official SR1 release though, so there might be another minor updated posting soon.
                      Devin Kendig
                      Developer
                      Chaos Group
                        Thanks for the info.
                        The only thing I miss in VrayforSU for the moment would be proxies/instancing.
                        As no features are going to be added for a next big release, I hope it will be on top of the list for the release after that.
                        (any idea about a time frame for that? ).
                        The ability to have proxies/instancing could be the way to overcome the crashing of SU on high poly models.
                          I said that there will not be any new features or workflow changes until the next big release.
                          We have just started the preplanning process... so no. It took us about a year to release this last version, and we hope to have a smoother development process this time around, but at the same time, we're taking on some bigger tasks this time... so we'll have to see. For a rule of thumb, don't even ask about an ETA until at least... November. By then we should have a pretty good idea of how much longer it will take us to pump the next version out. (Note, I did not say we'll have the product anywhere near finished by November, I just said that we should have an ETA by then, I hope nobody misunderstands this).
                          Devin Kendig
                          Developer
                          Chaos Group
                            Understood
                            (You were talking about the manual updates. My mistake.)
                              The SU Manual and Manual Scenes downloads are broken. I can't download either of them. Tried with Firefox and IE. Also, when clicking the download button it opens the link in both the current window and a new popup window.
