Another Bug. Purge Unused Material. SU crash
  • Another Bug. Purge Unused Material. SU crash
    I am sorry I have to report another bug again that quick.
    Try to Purge Unused Material in material editor. The SU crash.
    VRay verson SR1 just release yesterday.
    Cheers. ;D
    Re: Another Bug. Purge Unused Material. SU crash
    Please send all bugs through our bug tracking system, instead of our forum, as explained in this thread.
    http://asgvis.com/index.php?option=c...0&topic=3613.0
    Here is a direct link to the bug reporting page:
    http://asgvis.com/index.php?option=c...d=4&Itemid=142
    Here's why you should report bugs through our bug tracking system:
    Once we fix a bug, anyone that reported the bug is usually sent a "fixed" version of our product as soon as the bug has been repaired. That way the user can test it and confirm that the bug has indeed been repaired. Once we have confirmed this, we release the product to the public. So if you find a problem that you would like fixed, and you report it, you'll be one of the first to get a "fixed" version.
    Devin Kendig
    Developer
    Chaos Group
      We believe that we may have fixed this issue in the latest internal build of our product. If you experience this issue, please send us a bug report explaining how you were able to create the crash. We will then send you a link to the latest internal version of our product so you can test it.
      Devin Kendig
      Developer
      Chaos Group
        Thanks for fixing this bug. Unfortulatly I am using academic license. so i can't test the new version that you let me download from your internal link. do you mind to fix this bug on academic version then i can test it. many thanks ;D
          My apologies. If you respond to the support ticket with that information, we will gladly respond with the updated link.
          Devin Kendig
          Developer
          Chaos Group
              I have the same problem with version 6.0 SR1 (.74). When using this command SU starting to think about stars for a while....then the only thing i can do is to close SU.
                if you using the exiting file (ex. v.73 before) then render on v74. you will have the problem - wait for the sunset and midnight....the su will crash. What you have to do is purge the material under model setting to reduce number of unused material. Then hit render. then will go. i think it's the v.74 need to run though the whole model of material. that's why taking for ages.
