light cant work
  • light cant work
    hi,im using sketchup 6 and vray,when im trying to do a scene with a rectangular light on top,it give no light after render,and it is in totally black.i had follow all the instruction in the manual step by step,hence i hope that someone can kindly tell me whats the problem.is there anything i need to install to see a proper light?
    thanks in advance!
    Re: light cant work
    This is because the default settings in vfsu use the physical camera. The physical camera changes the exposure level of the scene which is whats causing your light to render black. You can either disable the physical camera or increase the multiplier on the light.
