Mapping curves with materials
  • Mapping curves with materials
    Hi there!
    I'm having a problem sorting this out, I've looked around the forums and used the search engine but still I can't find the solution to it.
    When you have a curved surface in Sketchup it's truely a sequence of surfaces that "look" like a curve. When I apply a material based on an image I always get the same result, it doesn't wrap around this "apparent" curve surface, it just shows the plane surfaces (hidden geometry) that build the curve.
    I'm attaching an image and hopeing someone can guide me through this...
    PD: The image from which I created the Material isn't small, so it isn't a tile issue... just in case you're thinking it isn't scaled properly.
    Re: Mapping curves with materials
    i'm no expert in sketchup, but in those situations i use 'projected' material.
    there few ways to do that.
    here is one: http://nl.youtube.com/watch?v=HHsRRLCAOm8
    hope it helps.
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      you might want to download the free UV tool ruby plugin written by WHat. go to sketchucation.com and download it from the ruby section. just have to look at it there though.
      http://www.nomeradona.blogspot.com/
      http://www.sketchupvrayresources.blogspot.com/
      http://www.nomeradonaart.blogspot.com/
        nomeradona
        Thanks a LOT, i tried it and works great and its so useful.
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
          Hi again!
          40th resolved the issue. The projection method worked like a charm.
          I'm adding the images so you can see the results:
          PD. if you're having the same problem mapping curves take a look at the YouTube video 40th mentioned...
            GOT IT! Thanks people!
