Same Texture on multiple objects yields different look
  • Same Texture on multiple objects yields different look
    This grass texture with bump was applied to both surfaces, only one of them showed the bump! Before doing some random reapplying materials and adjusting, the flat texture had a different UV value (completely smooth) than the other.
    Would this be a bug or is there a logical reasoning behind it?
    Rhino v4 + Vray 1.05.29<br /><br />The Creation Tank (http://www.thecreationtank.co.uk)
    Re: Same Texture on multiple objects yields different look
    Geometry with a displacement map that's attached to geometry with another material will prevent the displacement to render. Geometry with displacement has to be 100% isolated.
      nice grass by the way... ambient light grass?
        I'm not sure I'm new to this! Rendered on light cache with sketchup shadow lighting on , just a grass text plus bump_in this case displacement... Thanks I still need to try the solution
