Missing Groups in render
  • Missing Groups in render
    I'm new to this so bear with me have tried rendering a scene a couple of times from different angles and the finished render has some of the sketchup groups missing!?!$!!!
    Any ideas anyone.
    Thanks in advance
    Re: Missing Groups in render
    It's a known bug in the original release. The Service Release has fixed this.
    In the original release I used to work around this by converting the group to a component.
      Thanks ThomThom for prompt reply . I'm guessing also that if you explode all groups before render this would also cure problem?
        Yes it would. But then you'd be stuck if you need to edit the model afterwards as all geometry has merged. So if converting to component works I recommend doing that.
