I can't setup vray 1.05.03 for sketchup 7
  • I can't setup vray 1.05.03 for sketchup 7
    When I setup Vray 1.05.03 for sketchup 7 (I uninstalled SU 6 before), when I open Sketchup 7, there's a error report:
    Can you help me? :'(
    Re: I can't setup vray 1.05.03 for sketchup 7
    If you download the new installer for SketchUp 7 then you won't have any issues
    http://asgvis.com/index.php?option=c...ileinfo&id=565
      Thank you very much. Now I can install it.
        This problem is like my problem.
        I use Sketchup 7 and I install Vray For Sketchup 7 , but When I right click on my object , There is no Sketchup For Vray.
        I can see in ''Plugin'' , but I dont see When I click the right with mouse , while on the object.
        First image Sketchup 6 and Vray For Sketchup 6.
        And this is my problem. ( Last image.) How can you explain this ? I remove it , install again, but the same problem is continuous. Thank you.
          The "Make Unique Texture" is new to SU 7...as for the other stuff, you've installed a very old version of VfSU. Follow the link that I posted above and you should be fine
