Hello to all ...
I am in the mud!
I hope to be quite clear ... my English is a little 'low ... but I so need help!
I'm finishing a project for my portfolio and also to render the off ...
the problem is, if "load" and, believe me, not overloading the model with some components (plants), the program goes into error, not able to write to the temporary folder.
I know that unfortunately is a fairly common problem, I read in the forum, and then try the tips on how you are able acompletare work ....
I state that:
1) If you render a low resolution error does not occur
2) Error in displacement I solved (I think and hope) bringing even edge length (pix) at 50, the error also occurs with displacement amount set to 0
3) the error occurs both with network render on one machine!
4) because of the TEMP is overcrowded (22 gig) but I still have the disk space (15 gig), therefore, now I'm clearing! (and I hope this is of help) 5) any solution for indirect illumination ... IM; LC; QMC also set to not "heavily" mi manda in crash
6) immage sampler - AA -; adaptive DMC subd min 1 max 3 noire thresold 0.1
7) amount adaptive DMC sampler 1 min noise 8 samples thresold 0:01 mult subd 4
100) in my operating system is .... 64 views!
EDITED:
the sky multiplier was set to 11 (probably too much energy ???????)
However I would like some advice from you, feel free to ask me any information (even the most mundane, you never know ...) and will respond promptly! (they are attached to the forum as a leech!)
I hope with this post, to help resolve this problem that I think occurs when you consume too much memory, or you work heavily V-ray for sketchup!
I am in the mud!
I state that:
EDITED:
