I have just read a few threads, and hope this isnt to do with the SketchUp 7.1 release, but i have run into a problem with my diffuse map loosing its scale when i apply a bump map to the texture.
My process is that i import the texture, and scale it via sketchUp, then i use the Vray materials window to add a bump map, and in the past as you all know the bump map is automatically scalled to the size of the diffuse map.
Now what is happening, is that when i apply the bump map image the diffuse is loosing its scale in the image, please see attached.
Help this is bit of a major. Think i might have to downgrade sketchUp
Also SketchUp crashes when i try to apply certain images as textures via the import mode
please see link below for before and after test
http://s820.photobucket.com/albums/z...0bug%20images/
