Hi guys,
I have a major issue that I can no longer use sketchUp on the computers i have vray installed on.
The problem is that everything i do causes sketchup to stall for 1/2 - 1 minute, an example is say when i double click on a component to edit it, just doing that will cause this stall. Or if i make a single change to a material property within the vray materialseditor it causes the same thing to happen. So basically i try to do 1 action in either sketchUp or vray, and they both stall for 1/2 - 1 minute.
We have 2 machines that have vray on them in the office, and this occurs on both, but the model has no problems being used on machines that dont have vray. arghhh
But, Vray renders fine just as normal, it is just that i can now no longer work on my computer using sketchUp.
My machine is the most spec'd of all the machines in the office, and i have never had any memory or processing problems, but this has just happened since I updated sketchUp the other day. The IT guys at work thought that i had downloaded a virus, but since the file acts the same way on the other vray machine, then they have ruled this out.
Basically i am asking if anyone else has had this problem.
I think that my model may be corrupt in some way, because i can only replicate it with that particular model, so this might be a the problem.
If anyone can shed some light on this it would be great.
cheers
cheers
