I, like many others, was counting the days until the new version of VRay came out. As soon as that timer expired, I downloaded the new version and was thrilled to try out the new features. But, to my disappointment, I've been met with numerous problems that have made it virtually impossible for me to get any decent renderings out. Listed below are a bunch of things that I've noticed and would like some help solving. At this point, I cannot render anything for clients until I get these issues solved.
If you know the solution to any of these problems below, I'd be more than grateful to hear them. (And, no, there aren't 99 problems listed, but there still are quite a few.)
1. Everytime I open SketchUp, a prompt appears saying the following:
"Error Loading File VRayForSketchup.rb
127: The specified procedure could not be found. - C:/Program Files/Google/Google SketchUp 7/Plugins/VRayForSketchUp/VRayForSketchUp.so"
Does anyone know what this means, and, if necessary, what must be done to fix it?
2. Everytime I open the new DR Spawner I get the following message:
"'import site' failed; use -v for traceback
C:\Documents and Settings\All Users\Application Data\ ASGVIS\Python26\Lib\site-packages\Ft\Lib\__init__-py:47: DepreciationWarning: functions overriding warnings. showwarning<> must support the 'line' argument
self.message = messages[errorCode] % msgargs"
...and then a whole bunch of other stuff that looks the same until the very end when it says:
"Successfully initialized spawner. Waiting for jobs..."
Is this normal?
3. The light cache calcualtion time has greatly increased. I usually keep the default settings for the light cache, but calculation times have been much longer on this newer veriosn. On the old version, if the light cache calculation took about 30 seconds, it would take about 2 minutes on the newer version. And if the light cache calculation took 20 minutes on the old version, it would take over 2 hours on the new version. Are there any settings from the default settings that I must change to speed this up?
4. There's no longer an option to set "Low Thread Priority" in the Global Settengs tab. Has this been changed?
5. When using DR, if I open a new program (such as Word or Internet Explorer) while rendering, the cores from my computer disappear (the cores from the slave computers stay, though). As soon as I close the program I just opened, the cores return to the frame buffer.
What's the deal with that? Does this mean I can no longer run multiple programs while rendering?
6. When I save a scene as a jpeg, it won't save. I mean, I'll save it as a jpeg, but when I open the folder where I saved it, the jpeg is not there. It's almost like it disappears right after I save it. Only the png files stay after I save them. How can I save as other image formats? Specifically jpeg, tiff, and pdf.
7. In the DR Settings in the System tab, there's no longer an option to A) Send to each Node or B) Send to a Shared Folder. Whenever I use DR, I typically like to send all the data to a shared folder for the slave computers to access. Can I still do this on the new version?
8. The Material Preview is very slow. So far, I've only been able to preview one material (a flat green material with no added layers). Everytime I try to preview another material, the computer stalls and in the end I still get the red "X" in my preview box. I've even gotten a few Bug Splats while trying to view the preview. No matter how simple the material is, I can't preview it (except for that first time).
9. Whenever I try to apply any material to the VRay Infinite Plane and render, the render comes out completely black. Does anyone know why?
10. I cry in my sleep. Is that normal? :P
Is this normal?
