rendering problem..
  • rendering problem..
    my sketchup file size is 25mb. it renders well in old vray except for the shadows. the output shadows are different from the skp shadows? y this happens?
    i hv switched off the default lights, hidden lights,
    enabled physical camera(default settings),
    enabled gi and background with sky,
    all the other, the default.
    wen i tried to render in the latest version 1.48.66,it worked on 640x480, shadows also came well. but i needed a larger one, wen i do so, it stops abrutly saying there isnt enuf space in the temp folder. i restated after clearing temp and using disk clean up. but the same procedure is repeated again? after this, i cudnt render even with 640x 480 which was renderin well before.
    cud nyone pls.. send me a suggestion.. thnks in advance
