raw GI channels washed
  • raw GI channels washed
    Hi all,
    Since I use vray, the rawGI channels is washed or burned.
    I've tried with Reinhard or linear but the results are the same.
    Is that a bug or a wrong settings ?
    Thanks
    Re: raw GI channels washed
    not a bug I've had reported to us so far, so I'm going to cross my fingers and say it's something with the settings.
    Devin Kendig
    Developer
    Chaos Group
      Ok, well, this is a call to the community then
      Please teach me to do a correct GI and/or raw GI channel
        never used it. But could it be that you need to export in 32bit colour depth?
          nope.
          But I solved it.
          the raw GI is correct when I don't use the physical camera.
          Actually, it seems that the physical camera is applied after the channels in the vray pipeline, shouldn't be before ?
          Anyway, I got a correct channel and I will not use physical camera anymore.
          Had to tweak down the sun, 'to..
          Thanks for the replies
