BUG : Distributed Redering with the Last 48.89 release
  • BUG : Distributed Redering with the Last 48.89 release
    Could someone confirm that DR works OK with the last release of vray ?
    Thanks a lot
    Tom..
    update :
    Ok, I've tested myself.
    The DR is still buged. The slave machine is coming up, but say : can't open any texture files, the render is useless due to the dull bucket rendered by the slave one.
    Is the any new DR procedure to follow with the last release ?
    I've tested the 1.48.89 on Sketchup 7.1.4871. Slave machine with the same Vray version.
    Thanks a lot
    Re: BUG : Distributed Redering with the Last 48.89 release
    Yikes! confirmed. I couldn't use DR at the office when I tested it yesterday... this will not do! Working on a fix now.
    Devin Kendig
    Developer
    Chaos Group
      All right,
      Could we expect a rapid fixing exe or do have to way the next full update release ?
      This is kind of critical in a production type of workflow...
      thanks, besides that bug the current release is really a tremendous update..
      Tom
        DR's always a tricky one to track down, and we will roll out a full update release when it's fixed. Due to the nature of DR, we will not be able to release an update for DR only. The spawner needs to communicate with the plugin, and it seems that communication is currently having trouble. Either the information isn't being sent to the DR Spawner properly, or the DR Spawner isn't reading the data properly. As soon as we have a fix, and our testers give us a thumbs up, we will release an update.
        Devin Kendig
        Developer
        Chaos Group
          To Mr. Tom
          For correcting texture problem, check on Asset Collection in the SettingDR and in mode choose Send to each node. I hope this will fix the problem of empty bucket rendering by slave machine.
            Originally posted by baralmadhusudhan
            To Mr. Tom
            Thanks for your concerns.
            Believe me, I tried everything I could
