when i start the Spawner (RunDRSpawner) i got theses errors and the DR rendering won't start.
Code:
iMac:~ gf$ /Applications/ASGVIS/RunDRSpawner ; exit; /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:47: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument self.message = messages[errorCode] % msgargs /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:47: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 self.message = messages[errorCode] % msgargs /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:48: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument Exception.__init__(self, self.message, args) /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/__init__.py:48: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 Exception.__init__(self, self.message, args) /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument e.message), /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 e.message), /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:584: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument FtWarning) FtWarning: Catalog resource (file:///usr/local/share/4Suite/default.cat) disabled: Error retrieving resource 'file:///usr/local/share/4Suite/default.cat (/usr/local/share/4Suite/default.cat)': [Errno 2] No such file or directory: '/usr/local/share/4Suite/default.cat' Successfully initialized spawner. Waiting for jobs...
