Please help me with VRay error
  • Please help me with VRay error
    Hi There,
    i am a first time vray user and i am trying to use the software i have for a project coming up. As of right now i can create a render about every 5th time i hit the render button. The rest of the time i get an error message. I have checked out my error log but i have no idea how to read it or find out how i can fix it. Any help would be appreciated.
    Thanks,
    Amy
    Below is a copy of the error log.
    ;D ???
    =========System Information=========
    platform = win32
    country = UnitedStates
    language = English
    About to make our qapp
    after make qapp
    Made it after UIManager.initialize
    C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
    FtWarning, 2)
    FtWarning: Creation of InputSource without a URI
    None
    20.532000 seconds is how long it took to read C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    0.203000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
    (to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
    Traceback (most recent call last):
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py", line 215, in add_to_renderer
    vray_param = param.to_vray_param(renderer)
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py", line 92, in to_vray_param
    return self.value.to_vray_param(self.name, renderer, final_gamma )
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vraytypes.py", line 348, in to_vray_param
    return PyVRay.VUtils.DefStringParam(name, self.to_vray(renderer))
    TypeError: argument 2 of PyVRay.DefStringParam() has an invalid type
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py", line 328, in render
    self.addAssetsToRenderer( self )
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py", line 102, in addAssetsToRenderer
    ref.plugin.add_to_renderer( self )
    File "C:\Documents and Settings\All Users\Application Data\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py", line 408, in renderArchive
    self.render()
    Entering renderArchive
    About to start readArchive - C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    20.250000 seconds is how long it took to read C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    0.219000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
    self.render()
    22.047000 seconds is how long it took to read C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    0.297000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
    self.render()
    22.610000 seconds is how long it took to read C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    0.375000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
    13.422000 seconds is how long it took to add the plugins to our renderer
    146.843000 seconds is how long it took to render
    17.985000 seconds is how long it took to read C:\Documents and Settings\All Users\Application Data/ASGVIS/VfS/current_skp.xml
    0.125000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
    Re: Please help me with VRay error
    All you do is render the scene 5 times and you get this error? You're not changing any settings, moving the camera, adjusting any geometry in the scene, etc?
    Devin Kendig
    Developer
    Chaos Group
