20 meg Sketchup file crashes every time when VRay enabled
  • 20 meg Sketchup file crashes every time when VRay enabled
    20 meg Sketchup file crashes every time when VRay enabled. I am able to open the file and then CRASH!
    Sketchup 7.1 also didn't work.
    Mac OS X 10.6.6
    Sketchup 8.04810
    Vray 1.49.01
    MacBook Pro 2.53 mhz with 4 gigs of ram.
    Can I send tech support the file?
    I need to figure out what's wrong and render.
    Thanks!!!!
    Here's the file:
    http://tinyurl.com/4arbcxo
    Re: 20 meg Sketchup file crashes every time when VRay enabled
    Keep an eye on the amount of memory that is being used while rendering, you're probably running out of memory.
    Devin Kendig
    Developer
    Chaos Group
      If there's a limit, what is it?
      Otherwise I am wasting my time.
        Currently, SketchUp is a 32-bit application, so we are a bit limited by the amount of memory we're allowed to use. Pleanty of users have been able to render scenes that are well over 70mb, and some pretty complex scenes at that. It's all about the way you use the available resources. These may help a bit:
        http://software.asgvis.com/index.php...=16&Itemid=437
        http://software.asgvis.com/index.php...209&Itemid=480
        Devin Kendig
        Developer
        Chaos Group
          William ,make sure your texture correct rgb colors ,check in the photoshop .
          Sketchup 8 Vray for sketchup&nbsp; &nbsp; 01.49.01<br />Windows 7 32 Bit Core 2 Quad ,9600 GT<br />4gb DDR2 800
