I was wondering if anyone has had any issues regarding their license. When I first got the software, I installed on an old computer while waiting for a new one to be delivered. Since I've installed it on the new one, I've had a ton of issues with the license. More often than not, when I open sketchup, I get a prompt stating that it could not check out the license and to check if the license server is running and that I have an available license. When I try to open the license server, however, I get another prompt stating that it could not open due to another instance running. I typically have to remove the hardware key and restart sketchup in order for it to recognize the license. It will work fine for a while, but then sometimes when I start a rendering it tells me in the progress window that it could not obtain a license. Again, I have to remove the hardware key, plug it back in, often to no avail, forcing me to close sketchup entirely.
Other issues I've had are the stamp on the frame buffer not always working and sometimes when I close a rendering that's in progress, make some change and re-render, it tells me that a rendering is still in progress even though I've closed the frame buffer and progress window.
Anyone else having these issues?
Any help would be much appreciated!
