Proxy Problem
  • Proxy Problem
    Hi, i have a problem with proxy on my v-ray viewport.
    I have 3 models. Separatly, its working. But, i have problem when importing 3 model on the same time.
    it shows me 3 times the same model in the viewport.
    How can i fix it ?
    Thx !
    https://www.behance.net/Mala_Suerte
    Can you pack and share both the scene and the three proxy models with us? I'd like to test and see what is happening.
    Best,
    Ted Vitale
    V-Ray for SketchUp
    Product Manager | V-Ray SketchUp
    Chaos Group
      Thx for reply !
      you can download files here : https://we.tl/vBl1fyQiLc
      Thx by advance !
        Ted, Did you find what is the problem?
          Thank's for reply. So i do the test. Its working but only 50%. See the image.
          I haven't this problem with the v3.
          Moreover, the new proxy management system in version 3 is excellent. An external reference management system such as Autocad or indesign is very convenient. it allows us to see directly the path name. which is not the case in version 2.
          I forgot to mention one thing about my proxy problem.
          I have this problem only when I import files exported from 3dsmax vrmesh.
          not with proxy create for Sketchup model.
Name:	Test Proxy.jpg
            I think this has to do with how we are pulling the proxies into SketchUp in 2.0 initially and is a current limitation that is solved in the V-Ray 3 for SketchUp beta.
            Are they all being brought in together as one proxy? It may be a situation where you have to export them as all one proxy from max, or each object as an individual object. You may have to import each in a new scene and save, then combine the group as SketchUp components. Im not sure your workflow so I can't really say. Let me know if you see any V3 issues with proxies exported from Max, Maya or any other V-Ray application.
            Best,
            Ted Vitale
            V-Ray for SketchUp
            Chaos Group
