Mesh Clipper totally doesn't work for me
  • Mesh Clipper totally doesn't work for me
    Latest Vray, SketchUp 2016, 2017, Windows 7
    Even in the simplest scene, Mesh Clipper simply does not work. I don't know what else to say. It renders the object I've assigned as the clipping object.
    soved: It works when I turn off GPU acceleration
      Sorry for replying so late!
      Note that some features are not supported in GPU render mode. You can check the full documentation here
        Sorry if I piggyback this thread.. I noticed that the clipper doesn't work with simple planes: the clipping object has to be a solid. Is this true?
          The clipper bounding box should have a volume, and it will cut only areas which included in the bounding box only, if you want the simple plane to work, just go inside the clipper and rotate the plane or rotate the Axes.
          Regards,
          Mousa Abu Doush
          Architect | 3D Artist
          www.sketchuparchive.com
            The VRayMeshClipper works with closed mesh objects. If you want a plane clipper, simply use the native Section cut tool. V-Ray uses the same clipper plugin to utilize it.
            Kind regards,
            Peter Chaushev
            Peter Chaushev
            V-Ray for SketchUp | V-Ray for Rhino | Product Owner
            www.chaos.com
              Hey, just getting back here to let you I figured this out yesterday. Works like a charm, and makes for beautiful images. Nice
