I have found these bugs :
1-I have scattered a car proxy on a arc group using Skatter and noticed a strange result for the "Render ID" render element also for the render result itself:
You could download the file l from here:
https://www.dropbox.com/s/g8w4rgrnvh...atter.zip?dl=0
Note that normal copying doesn't make this issue.
2--If I Rename the sub materials in the Multi material and save and close the file and open it again, the Renamed materials will be duplicated with their old names.
3-The first Texture in the multi texture which ID's is 0 is not appear in VFB, I should change the ID order to start from 1 to make it works correctly. I have tested that with "Random by render ID" and with "Random by node name"
4--"Match color object in the model" and "Match color on the screen" is not working correctly with colors.
