Output Of Sketchup Render whilst V-Ray is enabled
  • Output Of Sketchup Render whilst V-Ray is enabled
    I keep having this problem when I try and render a normal Sketchup 2D render - usually just for the client to see the camera angle. I'm using V-Ray 3.4 and the most up to date Sketchup on a Apple Mac. When I disable the V-Ray extension Sketchup saves the 2d Render without the strange grey boxes.
    Does anyone else have this problem?
    Please see attached
    Please note that the grey bars are the 'Safe Frame' border in the viewport. You can turn them OFF from - Asset Editor > Settings > Render Output. Once you have the 'Safe Frame' toggled OFF, you should be able to export 2D Graphic without any issues.
      Georgi - Many thanks for this.... I just thought that this would have just affect the V-Ray render... but it worked, cheers
