Material binding
  • Material binding
    I'm having problems with material binding when using "some" bitmap textures. Most of my textures are working fine but when I set of them in the diffuse slot the changes doesnt appear in SU mtrl editor. I'm using Vray 3.60.01 on SU 2017 and 2018 and the problem is on both. I've managed to get it working by moving some of my textures and renaming them so it seems to be filename/path problem.
    It seems to be a problem with region specific characters (in my case ???) in the file names. Could you please fix this for the next release?
      Indeed this is a problem with non-Latin characters. We hope to have this solved in time for the upcoming hotfix 3.60.02.
      As a temporary workaround, you should be able to manually add the image file to the SketchUp material texture slot or simply rename the image files.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        Thanks Peter, I'm renaming my texture files as a workaround for now.
        BR
        Emil
