Vrmat Materials are not loaded in the scene
  • Vrmat Materials are not loaded in the scene
    Hello,
    When I made the steps in the attached video in a new SketchUp file, the Vrmat Materials are not loaded in the scene even if SketchUp is restarted.
    http://www.screencast.com/t/SmhBKOSFO
    Regards,
    Mousa Abu Doush
    Architect | 3D Artist
    www.sketchuparchive.com
    Can you try to switch to In Model Tab and see if the materials are properly added there?
    Also can you collect a list of materials that are not displayed properly.
    I noticed that Leather_A01_Brown_25cm is imported with wrong icon in In-Model tab but it's there.
      I have recorded another video for the issue, sometimes the vrmat materials will be deleted when I load them in the Asset editor, note that I was able to reproduce this issue on another machine.
      http://www.screencast.com/t/yeF7SjDbng
      Regards,
      Mousa Abu Doush
        When I open the Ruby Console, it gives this error :
        Error: #<TypeError: reference to deleted Entity>
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:53:in `entityID'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:53:in `onMaterialAdd'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:53:in `abort_operation'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:53:in `rescue in initialize'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:63:in `initialize'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/material_sync:24:in `new'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/material_sync:24:in `to_sketchup'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/callbacks/callbacks:62:in `handle_plugin_change'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/callbacks/callbacks:10:in `block (2 levels) in <module:Callbacks>'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/callbacks/callbacks:9:in `each'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/callbacks/callbacks:9:in `block in <module:Callbacks>'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/throttle:31:in `call'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/throttle:31:in `block in handle'
        SketchUp:1:in `call'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:53:in `onMaterialRemove'
        materials_observer(24):error: "No cached info for #<Deleted Entity:0x11973090>"
        ["disable_ui", false]
        helpers(54):error: Cannot open file C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\materials\Wood & Laminate\maps\Wood_Planks_C_Diff0.jpg
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/vray_to_sketchup_material_translator:112:in `set_sketchup_texture'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/vray_to_sketchup_material_translator:100:in `block in apply_texture'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/vray_to_sketchup_material_translator:118:in `preserving_size'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/vray_to_sketchup_material_translator:96:in `apply_texture'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/vray_to_sketchup_material_translator:12:in `apply'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/special_objects/material_sync:37:in `block in to_sketchup'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:50:in `call'
        C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:50:in `initialize'
        material_sync(64):error: Cannot open file C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\materials\Wood & Laminate\maps\Wood_Planks_C_Diff0.jpg
        Regards,
        Mousa Abu Doush
          I tried to run SketchUp as administrator to see if that could fix the issue, a when I loaded some water materials from the material Library in the Asset Editor, the Asset editor is corrupted, I have attached this error in a txt file:
Name:	Asset Editor.png
          Regards,
          Mousa Abu Doush
            Thank you for posting all this.
            Will investigate the first issue.
            The second one is already known, the dev team is onto it!
            Kind regards,
            Peter
            Peter Chaushev
            Let's keep in touch
              Thanks Peter!
              Regards,
              Mousa Abu Doush
                I'm experiencing these issues as well.
                  We are having a hard time reproducing this on our side. I have attached a zip with a materials_observer.rbc file. Please place the rbc file in "C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\ruby\observers" and let us know if this fixes the issue. This should stop the errors from being thrown. We shall see if it also avoids the actual replacing of materials.
                    I have tried that, but it didn't fix the issue, V-ray materials which have SketchUp images preview are not loaded in the scene.
                    Currently I am using V-ray on machine that has Windows 10, this issue seem occur only on windows 7.
                    Regards,
                    Mousa Abu Doush
                      I have the same issue.
                      I work on W7 pro (SP1) + SketchUp pro 2017 + VRay 3.60.02
                      Replace the "materials observer" have no effect.
                      For exemple:
                      Work "Leather_C01_Brown_25cm" or "Metal_Painted_Red_5cm"
                      Don't work "Veneer_D01_120cm" or "Paper_F_6cm"
                      Don't work when we have an image in diffuse slot?
                        Same here: https://www.youtube.com/watch?v=Kt-D...ature=youtu.be
                          Try to use the fix in this thread:
                          https://forums.chaosgroup.com/forum/...en-in-sketchup
                          Regards,
                          Mousa Abu Doush
                            This solution works, thank you!
                            • #15
                              The two issue may indeed be one and the same, yes. The fix that was posted in the other thread has already been merged. Can you confirm this issue is no longer reproducible in the nightlies, Mousa? If so, we can consider this resolved. Thanks
