Proxy model problem
  • Proxy model problem
    I import a proxy and resize it, when i choose "scale definition" it renders as its original size..
    Kindly note that V-Ray proxies are in a ready-to-render format and Scale Definitions are currently not supported.
      Thank you.. But previous vray versions was working nice with scale definition.. We need it because fur maker-make crowd and raytracer-spraycan or other spray plugins needs scale definition after scaling.. Or else, they spray the original sizes.. I hope the next version supports it..
        The dev team is looking into this. There is a solution that if deemed safe to implement, will make its way into the next version build.
        Kind regards,
        Peter
        Peter Chaushev
        V-Ray for SketchUp | V-Ray for Rhino | Product Owner
        www.chaos.com
          Thank you..
