Save time increase
  • Save time increase
    After opening asset editor, save time increases. As you can see in the attached video, save time normaly takes a few seconds, but, imediately after opening asset editor, the save time takes much much longer.
    Please help!
    P.S. In the video you can`t see the asset editor window opening beacuse the recording software only record the sketchup window, but you can see when i press the button.
    https://youtu.be/jbx74l_HHfU
    I assume this is reproducible only with specific projects? Could you please send one of them using a file-sharing service of your choice, either by emailing it at support@chaosgroup.com (include forum link in message) or in a private message addressed to me.
    Are there any 3rd-party plugins used beside V-Ray?
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      No, it happens in every project, rasing the save times after Asset Editor opens. Is there a way to reset V-Ray? Maybe a reinstall?
      I will send a project.
      Yes, I also use 3rd party plugins.
        Hi, Peter! I just sent you a file.
        Save time before opening Asset Editor: 2 seconds
        Save time after opening Asset Editor: 44 seconds
        Reinstalling VRAY did not fix the problem.
        I don`t know if it`s related, but I also have a problem with the Viewport Render. I get an instant bug splat if I press it.
          Isarescu, I had similar problem probably year ago with Vray 3.4, but there was problem with Windows updates and SketchUp. Maybe this information will help you to find a solution.
            Thanks! The issue is reproducible. A ticket for our dev team is already logged.
            Will get back to you when the cause of your issue is discovered.
            Kind regards,
            Peter
            Peter Chaushev
            Let's keep in touch
              Hi!
              Any news?
                This problem makes working with V-Ray extremely difficult and time consuming.
                  The problem is still scheduled for investigation.
                  As a workaround, could you please try closing the SketchUp Outliner panel and see if the issue persists?
                  Kind regards,
                  Peter
                  Peter Chaushev
                  Let's keep in touch
                    Thanks! That fixed it. I don`t even know why I had it enable, I knew it causes problems. I wish I new this a few weeks ago, this would have saved me so much frustration
                      Ok, thank you for the confirmation!
                      Peter Chaushev
                      Let's keep in touch
                        Outliner causes issues with many plugins from what I understand. I never use it and never have it open.
                        Matthew Valero, ASAI
