How much time do you save with use camera path??
  • How much time do you save with use camera path??
    hi all,
    What time can you save using this feature in irradiance map and light cache?
    the thing is that I created an animation and I timed how long it took every option and it gave me:
    Use path ON: LIGHT CACHE: 2':49"
    Use path OFF: LIGHT CACHE: 3':09"
    That's 20 seconds or 12% faster. Does it make sense?
    the animation is only 10 seconds... 300 frames?
    Thanks guys!
    Hi Juans,
    The Use Camera Path option will do the following:
    Instead of shooting LC & IM rays from the current camera position (for sampling), V-Ray will shoot the rays from multiple camera positions along the camera path at once.
    It will do it for every frame which sometimes helps in samples positioning and in general reduces flickering.
    Changing the sampling logic in this way can certainly affect the render time but the difference will vary depending on the specific scene.
    Keep in mind that the Use Camera Path options can be used for saving GI light map for the whole camera path by rendering a single frame.
    You can then load the map and render the entire animation without the per-frame GI pre-calculations.
    This will also avoid any flickering - the GI result will be perfectly stable throughout.
    Here's a short video that demonstrates how this is done:
    Note: The workflow is not that reliably in lengthy animations where the camera covers long distances. Some artifacts might occur.
    Regards,
    Konstantin
      Thank you very much! definitely I was missing loading the file. Now it makes sense! By the way there are some good videos on that youtube chanel.
