Hi, i open this topic for vray 3.6 also and vray next has the same problem.. I import a tree proxy, scale it down, right click and scale definition and scatter with raytracer plugin.. But trees comes at the beginning size in render..
Sketchup Scale definition problem
To scale and instance a Proxy you would first need wrap the proxy component within an extra component. Once this is done you can safely scale and then instance the top-level component.
If you scale the Proxy component directly, you will lose the transformation every time the Proxy preview is updated.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
- Likes 1
