disco ball glitter and glare reflection. is that possible?
  • disco ball glitter and glare reflection. is that possible?
    Hi!
    Anybody knows how to create this reflections projected from the mirror ball?
    and those glare light beams?
    I have model the ball and applied materials and light but...nothing the light is not reflected.....
    any idea?
    It would be helpful to the troubleshooting process if you showed a shot of the render you’re coming up with. One thing for sure is, turn on ‘ lens effects’ in the frame buffer and check glare and bloom, then re-render and see if thing are getting closer to what you’re wanting.
    Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
    Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
      You need to enable caustic, but I never used it and I'm not sure where to enable it at V-Ray Next. But you need to look in this direction to solve the problem.
        Here you can see caustics working at Rhino, but it should be the same at SU:
        https://docs.chaosgroup.com/display/...s%20Lesson%206
        Only one problem here - I can't find the global caustic option anymore.
          ok thanks! let me try with caustics on and i will share results!!
            Originally posted by Micha View Post
            ...and I'm not sure where to enable it at V-Ray Next.
            I found the option at the GI options, if the advanced mode is enabled and the CPU mode selected.
              Any progress? I'd love to see how things come out.
