Problem with multiple sketchup instances with latest stable Nightly (20200206)
  • Problem with multiple sketchup instances with latest stable Nightly (20200206)
    Since installing the recent nightly build, I cant seem to have more than one sketchup window open at a time. I usually keep 2 or 3 sessions of Sketchup open at time, but can't switch between them....the active sketchup window will remain active when i click on the other sketchup session on the task bar, or my usual method of using 'alt + tab' to switch between programs. When I have 2 sketchup sessions running I can finally switch to other if I keep trying and trying, but if I have 3 or more open I will have to close other sketchup sessions to be able to switch...the other SU windows just will not restore, or maximize or become 'active'.
    Anyone else experiencing this? V-Ray for SketchUp 4.10.02
    Build: 129920 Hash: 1e29d5d35 Date: Feb 6 2020
    V-Ray NeUI Version: 3.3.0 Build: 129916 Hash: 1e218b2ca Date: Feb 6 2020
    V-Ray Core Version: 4.30.01
    V-Ray AppSDK Version: 2.10.01
    Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
    Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
    Update 2 (v4.20.01) is now available. Could you please check if it fixes your problem?
    If the behavior you described persists, please see if SketchUp with V-Ray as the only 3rd-party extension runs fine as well as running SketchUp with your other 3rd-party extensions loaded except for V-Ray.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Update installed -- So far so good.
      Thanks for the update! There are a lot of new features to dig into.
