Hi, i tried to add graffiti on a wall, but it is limited to texture size.. For example, let's say my main diffuse texture is 10*10 tile and it repeats five times on the wall.. When i try to add graffiti it repeats five times.. Is there any way to position it on object space? I find a way but it is still limited to texture size..
Position graffiti on an object
To do this you could use Blend material. Just set as a base material the wall material(for example bricks) and as a Coat material use the paint for the graffiti. After that set a black and white bitmap for the shape of the graffiti and slot it in the Blend texture slot. Make sure that you have disabled the Tile U/V checks and set the Default Color to pure black(100% transparent)
Additionally, make sure that you have set the Texture Mode to Texture Helper.
