SpotLight Edit - Visual Editing
  • SpotLight Edit - Visual Editing
    When a Spotlight is first added to a scene SHIFT key allows for a 'visual' style to set light parameters ( see reference image) - after the spot light has been originally set is there a way to then edit this light using the same 'visual' type interface in the model space ?
    Thank you for your help if anyone can advise me here
Name:	Screen Shot 2020-08-05 at 3.43.53 PM.png
    Hi GDecker,
    Unfortunately the answer to your question is no.
    You can change all of the parameters in the Asset Editor but using the viewport widget is not an option.
    We can enable that functionality but we'll have to think of a good workflow to do so.
    I'll log it as a feature request.
    Konstantin
      Thank you for your reply - for me it would be great to have this feature as visually being able to see the area and distance of the light being cast by the fixture in model space is really helpful way to define these parameters - thank you for your consideration in this regard
      Greg
