Optimizing rendering time with ideal settings
  • Optimizing rendering time with ideal settings
    Hi all,
    I'm new here and of course I only have 2 months experience in rendering projects and I'm wondering what is the average time for rendering a project?
    Currently working on a 4000 x 2000 spherical rendering and it takes me more than 8 hours and it's just 25% completion for just 1 view.
    You may take a look from this https://storage.net-fs.com/hosting/6...LnUrd2PMIXBaEU
    My PC spec is below;
    • i9
    • RAM 64GB
    • GPU NVIDIA RTX 2070
    Looking forward to some guidance to a great rendering setting!
    Hey, if you are using Vray Next all you need to do is set Max subdivs to 50 and use bucket mode..then you can use noise threshold to control noise/quality .. the default value of .01 works nicely for most scenes
    For interior scenes you can use LC subdivs of 2000 ... and don't touch any other settings
    Render settings are quite easy now in Vray, usually you don't spend much time on them at all
    My settings above should work for 99% of the scenes.. you can go lower on noise threshold if you want a cleaner result (something like .007 or so ,or you can go up to .02 if you wanna use the denoiser and save a bit more of rendering time)
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hello, wyman ,
      Spending so much time on a single shot and reaching only 25% completion is definitely abnormal!
      Can you please state the version of V-Ray for SketchUp you currently use?
      If you feel ok to share that specific scene or at least a stripped-down version of it that exhibits the same slowdown, I can look into it and propose changes that can help you cut down the render time dramatically.
      You can send a scene by using the SketchUp menu Extensions > V-Ray > Pack Project and then ship the resulting archive to support@chaosgroup.com via a file-sharing service of your choice. A link to this forum thread for quick reference would also be appreciated.
      Kind regards,
      Peter
      Peter Chaushev
      V-Ray for SketchUp | V-Ray for Rhino | Product Owner
      www.chaos.com
        Thank you for your reply! I will definitely try it out and see how much shorter can I cut it. I notice when it's low light like night scene, it will take longer than day scene.
          Originally posted by Peter.Chaushev View Post
          Hello, wyman ,
          Kind regards,
          Peter
          Thank you Peter! I will look into all your comments and send it to support@chaosgroup.com. Looking forward to a faster rendering speed!
