Effects results doesn't show up after I render
  • Effects results doesn't show up after I render
    The effects result render channel doesn't show up after I finish my render. Is the denoiser render channel as good as the effects result one?
    Also why is not showing up?
    hi manishpaul_simon,
    effectsResult will store information about the denoised image combined with lens effects corrections. The Denoiser channel on the other hand will contain information only about the denoised image, so if you want to just use the Denoiser alone, you may not need the effectsResult output.
    However, the effectsResult channel should be visible when either Denoiser or Lens Effects are enabled. If you are not seeing it in the VFB, can you let us know the exact version of V-Ray for SketchUp you are using? You can check from Extensions > V-Ray > Help > About. Make sure that the denoiser option is enabled and also let us know whether you are using V-Ray or NVIDIA denoiser. Information about the GPU would be greatly appreciated.
    If this is happening only in a specific project, best would be to send it to support@chaosgroup.com. Make sure to mention forum post in the email.
    Nikoleta Garkova | chaos.com
