Where is "Alpha Contribution" in Vray Next for SU?
  • Where is "Alpha Contribution" in Vray Next for SU?
    Previous version has this feature called "alpha contribution" in Materials where you can set to 0 or 1 so you can have alpha channel on your model when render. Wonder where is this feature is in the new version? or is it called differently?
Name:	vray material screen.JPG
    You can refer to this post about the subject. Also updated link for Wrapper material in V-Ray Next for SketchUp you can find here.
    Nikoleta Garkova | chaos.com
      Thanks Nikoleta, I've been to both places you mentioned. I see you need to create a new wrapper material for Alpha contribution to appear. Can I turn an existing material that is already in the model to a "Wrapper" material rather than create a new one so I can have the alpha contribution setting? As you can see from my screen shot, non of my material has the "Wrapper" material setting where I can adjust alpha contribution.
        Yes, that is the idea behind the Wrapper material as it is used to specify additional surface properties per material. I've tried to prepare a visual example for you here. Hope it makes it more clear.
          Nikoleta, the clip you provided shows how to create new material assets, it just creates a new wrapper material. Doesn't show how my existing materials can have this wrapper additional surface properties you mentioned,
          Thanks.
            You will need to create a new Wrapper material and from there add your existing materials to get the additional properties
