Can´t seem to find my way around Lamps with EIS files in my projects - and it might be a combination of things in my workflow. Once I started in V-Ray I was happy just to get things done - no woories why it worked or not
But this thing seems to annoy me more and more. Let me clarify my workflow.
I work on laptop with files in my Dropbox - project files always set to be local as well. With lighting I fetch EIS files to each one and saves the EIS files in project folder.
I set up scenes on laptop, materials and ligting - with interactive render. Saves when I´m satisfied.
I open VPN connction to remote PC with better specs. This has my Dropbox as well. Open project - but now V-ray can not find EIS files to Each lamp. It´s like the EIS files is not "permanet gluede" to lamps in my model. Like the EIS light symbol in each lamp is "just a link" to the EIS file. Which would all so be just fine - if V-Ray just could follow the link and find the EIS file.
Why can´t the EIS file be "saved" with the EIS file so to speak. In this way I could always think "oh - I used this lamp with EIS file in another project" get it from the SU model - and it would work. But same thing happens - V-Ray can not follow the link to another project folder to fetch the EIS file.
IF my experience is the way it works - this would mean that You can not save a SU project with EIS lighting files to a USB pin and open it on another PC with SU and V-Ray, an render it. The setup You did on lighting will be in file - but V-Ray will not find the EIS files. I think this can not be right - so I must do something wrong.
What is it I do not see ? PLEASE
