Is the following item in point 9 possible?
1. I have a Sketchup scene of an exterior isometric view of a building.
2. I populate the scene and create “scenes” in Sketchup to control the camera orientation. One scene is called “west” and shows the building from the west.
3. I place objects in the scene from Cosmos (people, trees, street furniture, etc. I assign them to a layer in Sketchup called “objects-west”.
4. I light my scene with an HDRi and SunLight with an override on the direction of the HDRi and custom angle and elevation on the SunLight.
5. I render the scene, tweak the VFB settings, save them as a preset and am happy. I also save my Sketchup file and save my render settings.
6. I switch to the other Sketchup “scene” called “east” which just rotates the camera to view the building from the east.
7. I re-render the scene and am not happy with the placement of my Cosmos models or the lighting/shadows so I duplicate the objects and assign the duplicates to a new layer called “objects-east”. I then relocate the “objects-east” models to where they work better in the scene.
8. I duplicate the HDRi, turn the original one off and rotate the new one until it casts shadows that I’m happy with.
question:
9. how can I either
a. duplicate the sun, save one as Sun-east and one as Sun-west and give them individual angle/elevation values and switch them on and off depending on my current render view (east or west)? Or
b. Save presets for the SunLight settings so that I can just load a file that amends the SunLight settings?
Ideally you should be able to save/export all your lighting settings including SunLight settings (on/off, colour, angle, elevation, map, etc), Dome lights (on/off, maps, intensity, direction, etc).
I think I should be able to switch my view in Sketchup (either manually or with a camera preset or a scene) and then load files for Render Settings (which I can), VFB settings (which I can) and lighting settings (which I don’t think I can).
Thanks,
Andy
question:
9. how can I either
Thanks,
Andy
