If I place a decal on a wall that has a bump map, will the decal not be affected by that? If not, we need that feature! - pretty sure I saw Lumion do it in a demo.
Very good idea.
I just tested it and unless I'm mistaken it doesn't work.
I tried to put the same Bump texture in the Bump of the Decal material, it could work, but then we have a problem of UV mapping that does not match.
Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
Sketchup PRO 25.0.634 + V-Ray 7.00.03
3DS Max 2025.3 + V-Ray 7.00.08
3DS Max 2026 + V-Ray 7.00.08
Chaos Vantage 2.8
GeForce Studio Ready Driver Version 572.16
I’d imagine that it could be a tick box in the settings of the decal they would allow it to be affected by bump of underlying material. Seems like something you absolutely need.
Another request would be for the decal to maintain the proportions of the graphic you are using, or some
kind of setting that matches the proportions of it.
Also, I’d love to be able to see the decal texture under the decal settings and not just the generic decal symbol.
Would be useful to have it work as you'd expect, however you can achieve a match with some tweaking of the tiling, if that helps until there's maybe an update
