Is it possible to exclude an object(s) from the contour feature? I am using a few instances of fur and it just looks like a mess when countours are applied to it.
Exclude from Contours
This is not possible at the moment.
However there is workaround, use the Toon material insted of the Contours option(they are kinda the same). Apply the material on the objects you wish the contours to be visible.
I know this is not the most convenient solution but it possible to have some objects with ontours and some not.
Hello, Matthew,
Objects cannot be excluded from the global contour effect but their materials can (in your case, the materials used by Fur assets).
Here are the steps achieve this:- Select a material.
- Add a Contour attribute to it.
- Set the Contour opacity to 0.
Regards,
PeterPeter Chaushev
Let's keep in touch
