Locking the Vray Asset Editor or Setting it to Show on Top
  • Locking the Vray Asset Editor or Setting it to Show on Top
    Hi guys, I don't work with two monitors at the moment so I'm facing this problem a lot. I'd like to make the Vray Asset Editor 'always show on top' when I'm checking the render in the Vray Frame Buffer. The problem I'm facing right now is that when I select the Asset editor, the VFB window minimizes and it's just the Sketchup Window that shows up. It would be great if you guys could add a feature to sort of lock the Asset Editor window or make it show always on top. Like how the purref "always on top" mode works. Thankyou So at present, I sort of tile the Sketchup window to the left & the Vray Frame Buffer to the right and then tweak the settings the in the Vray Asset Editor. I hope you understood my problem.
    Hello, Manish,
    We are aware the VFB window occasionally (and quite randomly) sinks below the main SketchUp window. This is mainly a macOS issue although it very rarely occurs on Windows as well.
    Next time you experience it, please use the SketchUp menu Extensions > V-Ray > Help > License > Release License and then reopen the Asset Editor and VFB.
    Work on a solution is already underway, so there is no need to devise a workaround.
    Will keep you updated on our progress.
    Peter Chaushev
    Let's keep in touch
