How to place a shadow to a HDRI-Background in CUDA-Mode?
  • How to place a shadow to a HDRI-Background in CUDA-Mode?
    Hello,
    I need urgent help with the following problem:
    Precondition:
    I work exclusively with the CUDA engine in CUDA + CPU mode!
    V-Ray Version 6
    Task:
    I want to insert an object in a background image (HDRI) and get the shadow in the background.
    In V-Ray 5 I had no Problems with this task.
    Unfortunately, this does not work for me as shown in the following video:
    https://www.youtube.com/watch?v=mMmv2GtfImE
    and
    https://www.youtube.com/watch?v=IuBxbY4R_bo at time 4:50
    I have tried all possible combinations in the wrapper-Material.
    Unfortunately without success.
    If I calculate only I im in the CPU engine I get the shadow displayed in the VFB.
    Thank you very much for a very quick help.
    Regards Ronald
    Hello, Ronald,
    Thank you for reaching out!
    We have identified the issue preventing the matte effect of Wrapper materials to appear when using V-Ray GPU.
    An upcoming hotfix will contain a permanent solution for it.
    In the meantime, there are a couple of workarounds you can use to overcome the issue:
    • Workaround A:
      - Open the SketchUp Ruby Console (Window > Ruby Console or Extensions > Developer > Ruby Console depending on the version of SketchUp installed).
      - Paste the following script in the console. Make sure you substitute Wrapper_v6 with the actual name of your Wrapper material and keep the "/" in front of the name. Then, press 'Enter'.
      Code:
      scene = VRay::Context.active.scene
      	scene.change {
      	scene["/Wrapper_v6"][:alpha_contribution_tex] = -1
    • Workaround B:
      Use a Matte Wrapper material created in V-Ray 5. This can be done by opening the V-Ray Asset Editor and load a V-Ray 5 Wrapper vrmat file (the 'Import Asset File' located at the footer of the Asset Editor).
      If you have the V-Ray 5 Material Library still existing on your system, simply navigate and load the following file.
      %UserProfile%\Documents\V-Ray Material Library\AEC\materials\v5.0\Materials\Diagrammatic\ Matte Shadow Receiver.vrmat
      Alternatively, download and load it from here:​​ Matte Shadow Receiver.zip
    Hope this helps!
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Hi Ronald,
      I just want to notify you that V-Ray 6 for Rhino, hotfix 1 was recently released and it addresses the Wrapper issue.
      Note that materials created with the official V-Ray 6 or the beta will have to be re-created to work correctly.
      Konstantin
