Save Image File Path Overwrite Workaround?
  • Save Image File Path Overwrite Workaround?
    Does anyone know if it is possible to have V-Ray change the file path name automatically for consecutive renders? Here's what I do. I render the first scene and have the file path name set as "Render 1". It saves the image to the file path I selected. Then, if I move to another scene, render, but forget to change the file path name, it overwrites the first scene's render.
    Is it possible to either stop it from overwriting or to automatically create a new file path name so it doesn't overwrite?
    Hi calvin_ode​,
    A new file path will automatically be generated if you perform a Batch Render or render an animation.
    For manual renders you have to manually change it.
    Adding an option that controls this behavior might be possible.
    I'll log it as a feature request in our bug tracking system.
    Thanks you for bringing this to my attention,
    Konstantin
